Saltar al contenido principal
Sony Xperia T2 Ultra Dual Top Speaker Replacement
Qué necesitas
  1. Sony Xperia T2 Ultra Dual Top Speaker Replacement, Rear Case: paso 1, imagen 1 de 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Top Speaker Replacement: paso 2, imagen 1 de 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Top Speaker Replacement, Removing the internal cover: paso 3, imagen 1 de 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Top Speaker Replacement: paso 4, imagen 1 de 2 Sony Xperia T2 Ultra Dual Top Speaker Replacement: paso 4, imagen 2 de 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Top Speaker Replacement, Top Speaker: paso 5, imagen 1 de 2 Sony Xperia T2 Ultra Dual Top Speaker Replacement, Top Speaker: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the top speaker carefully.
Conclusión
2 personas más completaron esta guía.
Shiqing Wang
Miembro Desde 03/01/17
155 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G3, Harley Spring 2017 Miembro de IUPUI, Team S1-G3, Harley Spring 2017
IUPUI-HARLEY-S17S1G3
4 Miembros
3 Guías creadas
3 comentarios
Sony t2 ULRA PHONE How Display OR TOUCH DIZASTER replacement
Rajib Kalita - Contestar
I can see and touch is work properly but display is broken, please tell what is replace display or touch disaster?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 2,033
