Saltar al contenido principal
Sony Xperia T2 Ultra Dual Midframe Replacement
Qué necesitas
  1. Sony Xperia T2 Ultra Dual Midframe Replacement, Rear Case: paso 1, imagen 1 de 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Midframe Replacement: paso 2, imagen 1 de 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Midframe Replacement, Removing the internal cover: paso 3, imagen 1 de 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Midframe Replacement: paso 4, imagen 1 de 2 Sony Xperia T2 Ultra Dual Midframe Replacement: paso 4, imagen 2 de 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 13-3, Staggers Fall 2014 Miembro de USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 2,332
