Saltar al contenido principal
Sony Xperia Sola Headphone Jack Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Sony Xperia Sola Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Lay phone face down with camera away from you as shown.
  2. Sony Xperia Sola Headphone Jack Replacement: paso 2, imagen 1 de 2 Sony Xperia Sola Headphone Jack Replacement: paso 2, imagen 2 de 2
    • Push the cover up as shown in first picture. Then lift to remove as shown in the second.
  3. Sony Xperia Sola Headphone Jack Replacement: paso 3, imagen 1 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 3, imagen 2 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 3, imagen 3 de 3
    • The screws unfortunately require different heads on the screw driver so you will want to use the 26 Bit Kit. Make sure to keep them separated once removed by using the magnetic mat.
  4. Sony Xperia Sola Headphone Jack Replacement: paso 4, imagen 1 de 2 Sony Xperia Sola Headphone Jack Replacement: paso 4, imagen 2 de 2
    • Slide a spudger or plastic opener under the white cover (as shown) and push toward your body to pop the cover off the end.
  5. Sony Xperia Sola Headphone Jack Replacement: paso 5, imagen 1 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 5, imagen 2 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 5, imagen 3 de 3
    • Again, using the 26 Bit Kit and the magnetic mat. These screws would be revealed by the removal of the white cover.
  6. Sony Xperia Sola Headphone Jack Replacement: paso 6, imagen 1 de 2 Sony Xperia Sola Headphone Jack Replacement: paso 6, imagen 2 de 2
    • Slide either the plastic opener or the spudger under the black cover that is outlined and remove.
  7. Sony Xperia Sola Headphone Jack Replacement: paso 7, imagen 1 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 7, imagen 2 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 7, imagen 3 de 3
    • You can do this from any side. Slide a flat object, either the plastic opener or the spudger, from the side and lift. You may feel resistance on the sides where the buttons are located, but this is normal.
  8. Sony Xperia Sola Headphone Jack Replacement: paso 8, imagen 1 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 8, imagen 2 de 3 Sony Xperia Sola Headphone Jack Replacement: paso 8, imagen 3 de 3
    • The jack will be the the back cover you just removed. Insert removal tool, tweezers, into the jack and lift up, the jack will pop out. Replace with your new jack.
Conclusión
3 personas más completaron esta guía.
Cary Drew
Miembro Desde 09/25/14
866 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Brown Fall 2014 Miembro de USF Tampa, Team 1-1, Brown Fall 2014
USFT-BROWN-F14S1G1
4 Miembros
5 Guías creadas
Un comentario
Need to include screw measurements to the nearest mm.
Dan Brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 5
Todo El Tiempo: 348
