Saltar al contenido principal
Sony Xperia Sola Camera Module Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Sony Xperia Sola Camera Module Replacement, Lay the phone as shown.: paso 1, imagen 1 de 1
    • Place phone down with screen side down and camera side facing up as shown.
  2. Sony Xperia Sola Camera Module Replacement, Remove the back cover.: paso 2, imagen 1 de 1
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  3. Sony Xperia Sola Camera Module Replacement, Remove the screws.: paso 3, imagen 1 de 3 Sony Xperia Sola Camera Module Replacement, Remove the screws.: paso 3, imagen 2 de 3 Sony Xperia Sola Camera Module Replacement, Remove the screws.: paso 3, imagen 3 de 3
    • Locate and remove the five (5) screws on the phone, using the 26 Bit Kit. The screws are at the top and the bottom of the phone as shown.
  4. Sony Xperia Sola Camera Module Replacement, Remove bottom white cover.: paso 4, imagen 1 de 2 Sony Xperia Sola Camera Module Replacement, Remove bottom white cover.: paso 4, imagen 2 de 2
    • Pry off the bottom white cover by using the opening tool as a lever.
  5. Sony Xperia Sola Camera Module Replacement, Remove more screws.: paso 5, imagen 1 de 2 Sony Xperia Sola Camera Module Replacement, Remove more screws.: paso 5, imagen 2 de 2
    • Locate and remove the 2 additional screws, using the 26 Bit Kit, that are revealed. These are marked as shown.
  6. Sony Xperia Sola Camera Module Replacement, Remove black cover.: paso 6, imagen 1 de 2 Sony Xperia Sola Camera Module Replacement, Remove black cover.: paso 6, imagen 2 de 2
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  7. Sony Xperia Sola Camera Module Replacement, Disconnect the battery's circuit.: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  8. Sony Xperia Sola Camera Module Replacement, Remove the phone's inner back cover.: paso 8, imagen 1 de 3 Sony Xperia Sola Camera Module Replacement, Remove the phone's inner back cover.: paso 8, imagen 2 de 3 Sony Xperia Sola Camera Module Replacement, Remove the phone's inner back cover.: paso 8, imagen 3 de 3
    • Turn the phone onto its side, insert plastic opening tool into seam, and gently remove cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  9. Sony Xperia Sola Camera Module Replacement, Remove the additional power circuit.: paso 9, imagen 1 de 1
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  10. Sony Xperia Sola Camera Module Replacement, Repeat for the circuit on the top end of the battery.: paso 10, imagen 1 de 2 Sony Xperia Sola Camera Module Replacement, Repeat for the circuit on the top end of the battery.: paso 10, imagen 2 de 2
    • Use the tweezers to lift up on the circuit located at the top left.
  11. Sony Xperia Sola Camera Module Replacement, Remove the motherboard.: paso 11, imagen 1 de 1
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  12. Sony Xperia Sola Camera Module Replacement, Place the board as shown.: paso 12, imagen 1 de 1
    • This will ensure easy removal of the camera module.
  13. Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: paso 13, imagen 1 de 3 Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: paso 13, imagen 2 de 3 Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: paso 13, imagen 3 de 3
    Comprar
    • Using the tweezers remove the camera from the power source.
  14. Sony Xperia Sola Camera Module Replacement, Remove the camera module.: paso 14, imagen 1 de 1
    • Pick up board and remove camera module. The module should seem to just pop out.
Conclusión
2 personas más completaron esta guía.
Cary Drew
Miembro Desde 09/25/14
866 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-1, Brown Fall 2014 Miembro de USF Tampa, Team 1-1, Brown Fall 2014
USFT-BROWN-F14S1G1
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 434
