Saltar al contenido principal
Sony Xperia L2 LTE Motherboard Replacement
Qué necesitas
  1. Sony Xperia L2 LTE Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Sony Xperia L2 LTE Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Motherboard Replacement: paso 2, imagen 1 de 3 Sony Xperia L2 LTE Motherboard Replacement: paso 2, imagen 2 de 3 Sony Xperia L2 LTE Motherboard Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Motherboard Replacement: paso 3, imagen 1 de 1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Motherboard Replacement: paso 4, imagen 1 de 2 Sony Xperia L2 LTE Motherboard Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Motherboard Replacement: paso 6, imagen 1 de 3 Sony Xperia L2 LTE Motherboard Replacement: paso 6, imagen 2 de 3 Sony Xperia L2 LTE Motherboard Replacement: paso 6, imagen 3 de 3
    • Use blue plastic opening tool to pry off the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 478
