Introducción
To complete this guide you will need to open the phone following the steps below to replace your keyboard module, using the required tools.
The battery should be removed before working on the phone internals.
Qué necesitas
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Remove adhesive black tape at the bottom left of the phone.
Then remove the clip by pulling it up and slide out the wide orange cable(seen in picture 2).
By using the tweezers, unclip the cable at the bottom right by pulling it up.
Finally, remove the keyboard module by pulling it up with the tweezers from right to left.
2 personas más completaron esta guía.
