Introducción
This guide will help you disassemble your phone to the camera, and then it will teach you how to replace the camera.
The battery should be removed before working on the phone internals.
Qué necesitas
You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
Using the tweezers lift the plate out of the clamps, from left to right.
Then remove the whole plate off the phone.
Using the tweezers, slowly peel the white sticker off from the top right corner to the left bottom corner.
Once the sticker is off, unclip the clip on the top left side(below the camera). Then slide out the wide orange cable below the clip.
Then lift up the board carefully and remove the clip and cable on the back.
Pop the camera out using your fingers, and then unclip it off the board using tweezers.
2 personas más completaron esta guía.
