Saltar al contenido principal
Sony Xperia E4 Touch Screen Glass / LCD Display Replacement
Qué necesitas
Resumen del Video
  1. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: paso 1, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: paso 1, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: paso 1, imagen 3 de 3
    • Remove the back cover and any installed SIM and memory cards.
    • There are 8x black screws Torx T4. Remove them.
  2. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 2, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 2, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 2, imagen 3 de 3
    • Remove the small black rubber at the lower left corner.
    • Under it is the battery flex cable, disconnect it.
  3. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 3, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 3, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 3, imagen 3 de 3
    • Use a plastic tool to separate the middle frame.
    • The battery is glued to the middle frame with an adhesive tape.
    • Loudspeaker
  4. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: paso 4, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: paso 4, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: paso 4, imagen 3 de 3
    • Disconnect the touch screen flex cable.
    • Under it is the LCD flex cable. Disconnect it also.
  5. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 5, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 5, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 5, imagen 3 de 3
    • Remove the logic board.
    • Be careful for the flex cables.
  6. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: paso 6, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: paso 6, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: paso 6, imagen 3 de 3
    • Cover the glass with a scotch tape.
    • Warm the glass for about minute.
    • With a cutter lift a little the glase to make a room for the plastic tool.
  7. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 7, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 7, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Carefully put the plastic tool between the glass and the LCD.
    • The tool must be thin, you can use also a plastic card.
    • Periodically warm the glass.
    • Remove the display frame.
  8. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 8, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 8, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 8, imagen 3 de 3
    • Use only plastic tools and don't force the LCD.
  9. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 9, imagen 1 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 9, imagen 2 de 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 9, imagen 3 de 3
    • Install adhesive tape.
    • It's easier if you order your touch screen together with adhesive sticker.
    • Start with the reassembling.
  10. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: paso 10, imagen 1 de 1
    • That's all.
Conclusión
12 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
192,056 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,525 Guías creadas
4 comentarios
Grazie! È stato davvero utilissimo. :)
Andrea DePa - Contestar
Doesn't the original glass and digitalizer come out with its biadesive?
marco bigoni - Contestar
First Timer here:
I've followed this and replaced the cracked screen (the clear bit).
But it still looks cracked; could it be that I have a cracked LCD thingy as well? (is that the black bit?).
If so what's the part number for that?
MartynJ - Contestar
Why don't you just buy the screen which has the lcd and digitiser already assembled? That will save you a lot of hassle for only a few £'s more :)
Clems - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 20,286
