Saltar al contenido principal
Sony XPERIA Tablet Z Screen Replacement
Qué necesitas
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: paso 1, imagen 1 de 3 Sony XPERIA Tablet Z Screen Replacement, Screen: paso 1, imagen 2 de 3 Sony XPERIA Tablet Z Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: paso 2, imagen 1 de 3 Sony XPERIA Tablet Z Screen Replacement: paso 2, imagen 2 de 3 Sony XPERIA Tablet Z Screen Replacement: paso 2, imagen 3 de 3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: paso 3, imagen 1 de 1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: paso 4, imagen 1 de 1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: paso 5, imagen 1 de 1
    • Clean adhesive from perimeter of frame to prepare for new screen.
Conclusión
8 personas más completaron esta guía.
Gustavo Correa
Miembro Desde 07/11/17
373 Reputación
1 Guía escrita
Equipo
IUPUI, Team S5-G1, Harley Summer 2017 Miembro de IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Miembros
3 Guías creadas
5 comentarios
اريدشراءاريدشراءشاشه جديده
kore ares - Contestar
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Contestar
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Contestar
Wooo its self explanatory.Good work
Duncan Mwaniki - Contestar
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 81
Todo El Tiempo: 7,137
