Saltar al contenido principal
Sony XPERIA Tablet Z SIM and SD card reader Replacement
Qué necesitas
  1. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: paso 1, imagen 1 de 3 Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: paso 1, imagen 2 de 3 Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
    • Remove cover
  2. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, locating the SD card reader: paso 2, imagen 1 de 1
    • Locate the SD card reader in the bottom left hand corner
    • Remove all screws connecting the metal plate to the device.
  3. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Lift up: paso 3, imagen 1 de 1
    • After all the screws have been removed lift the circuit board up to wiggle free.
  4. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Disconnecting electrical tape.: paso 4, imagen 1 de 1
    • After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
    • Once placed there lift up and disconnect the SD card reader from the device.
Conclusión
Una persona más ha completado esta guía.
Martin Luna
Miembro Desde 09/24/14
1,873 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 15-6, Remmell Fall 2014 Miembro de USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Miembros
7 Guías creadas
Un comentario
How long did it take to complete???
Steve Donnelly - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 2,209
