Saltar al contenido principal
Sony XPERIA Tablet Z Motherboard Replacement
Qué necesitas
  1. Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Remove the back cover by using the plastic opening tools.
  2. Sony XPERIA Tablet Z Motherboard Replacement: paso 2, imagen 1 de 2 Sony XPERIA Tablet Z Motherboard Replacement: paso 2, imagen 2 de 2
    • Disconnect the battery by lifting the connector straight up from the motherboard with a plastic opening tool or equivalent.
    • Do not pry on the wires. Only pry up on the white plastic part of the connector that is closest to the battery itself.
  3. Sony XPERIA Tablet Z Motherboard Replacement: paso 3, imagen 1 de 2 Sony XPERIA Tablet Z Motherboard Replacement: paso 3, imagen 2 de 2
    • Pry up the tape and ribbon cable connector for front facing camera.
    • Remove front facing camera and cables.
  4. Sony XPERIA Tablet Z Motherboard Replacement: paso 4, imagen 1 de 1
    • Slide the ribbon cable out of motherboard.
    • This cable is the only one in this guide that slides out from the motherboard in a motion that is parallel to the motherboard.
  5. Sony XPERIA Tablet Z Motherboard Replacement: paso 5, imagen 1 de 3 Sony XPERIA Tablet Z Motherboard Replacement: paso 5, imagen 2 de 3 Sony XPERIA Tablet Z Motherboard Replacement: paso 5, imagen 3 de 3
    • Use a Phillips head #0 screwdriver to remove the 3.06 mm screws from the Micro USB retaining plate.
    • Remove the cover plates.
    • There is plastic plate and a metal one.
    • Remove the USB port partially from its position. It can stay connected just moved out of the way.
  6. Sony XPERIA Tablet Z Motherboard Replacement: paso 6, imagen 1 de 2 Sony XPERIA Tablet Z Motherboard Replacement: paso 6, imagen 2 de 2
    • Use a Phillips head #0 screw driver to remove the 3.43 mm screws on the volume control retaining plate.
    • Remove the volume control.
  7. Sony XPERIA Tablet Z Motherboard Replacement: paso 7, imagen 1 de 1
    • Lift up the connector for the rear facing camera.
    • Remove the rear facing camera.
  8. Sony XPERIA Tablet Z Motherboard Replacement: paso 8, imagen 1 de 2 Sony XPERIA Tablet Z Motherboard Replacement: paso 8, imagen 2 de 2
    • Use a Phillips head #0 screwdriver to remove the 3.43mm cover plate screws for headphone port, power button, and status LED assembly.
    • Remove headphone port, power button, and status LED assembly cover plate.
  9. Sony XPERIA Tablet Z Motherboard Replacement: paso 9, imagen 1 de 2 Sony XPERIA Tablet Z Motherboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the connectors for the headphone port, power button, LED from the mother board.
    • Remove the headphone port, power button, and LED from the mother board.
  10. Sony XPERIA Tablet Z Motherboard Replacement: paso 10, imagen 1 de 3 Sony XPERIA Tablet Z Motherboard Replacement: paso 10, imagen 2 de 3 Sony XPERIA Tablet Z Motherboard Replacement: paso 10, imagen 3 de 3
    • Disconnect the 3 ribbon cable connectors from the mother board near the USB port and speaker.
  11. Sony XPERIA Tablet Z Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the motherboard by gently prying up. Once it is loosened from the adhesive you may need to slide it away from the battery while lifting.
Conclusión
3 personas más completaron esta guía.
Equipo
IUPUI, Team S5-G1, Harley Summer 2017 Miembro de IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 2,036
