Qué necesitas
Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
Remove cover
30 personas más completaron esta guía.
14 comentarios
I was able to replace the usb port but my tablet still wont charge or be recognized as usb when connected to PC. What can this be? Any idea? Please I need help.
I also replace charging port with same result, I was not able to find a solution online so until I can find a magnetic docking station for sale I have bypassed the charging port and connected my usb direct to the battery with 100% result.
My tablet never goes outdoors so the waterproof covers is not needed, bloody well good job as there now is a usb cable poking out the cover and sealed closed with electrial type
Higgs -
I was able to replace my connector after much difficulty (the part I received wasn't the exact size so I had to cut a little bit and force a lot!). I worked great... For approx. 2 weeks. Now I'm back to square one. I was wondering if it would be possible to fabricate a magnetic dock (or similar), since the official one seems impossible to find?
Lynx -
I replaced the usb port and had the same problem as esteeizola because my battery was completely drained. (IMHO Sony has a design fault with their USB ports. They are rubish. If you get more than 200 plug/unplug operations out of a Sony USB you are very lucky).
What happened was that USB drew 4 to 5 milli-amps for about 10 to 12 amps. During this time the red led was lit but the device remained dead. Finally, USB started drawing a normally charging current (a very pathetic 300 milli-amps from what I can tell.) And the device came to life say the battery was 2% charged.
I don't what the reason is for this behavior but it certainly is very confusing and frustrating,
