Saltar al contenido principal
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
Qué necesitas
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: paso 1, imagen 1 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: paso 1, imagen 2 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: paso 2, imagen 1 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: paso 2, imagen 2 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: paso 2, imagen 3 de 3
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: paso 3, imagen 1 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: paso 3, imagen 2 de 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: paso 3, imagen 3 de 3
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
Conclusión
2 personas más completaron esta guía.
Martin Luna
Miembro Desde 09/24/14
1,873 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 15-6, Remmell Fall 2014 Miembro de USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,967
