Saltar al contenido principal
Sony XAV-AX100 Volume Knob Replacement
Qué necesitas
  1. Sony XAV-AX100 Volume Knob Replacement, USB Cable: paso 1, imagen 1 de 3 Sony XAV-AX100 Volume Knob Replacement, USB Cable: paso 1, imagen 2 de 3 Sony XAV-AX100 Volume Knob Replacement, USB Cable: paso 1, imagen 3 de 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Volume Knob Replacement: paso 2, imagen 1 de 2 Sony XAV-AX100 Volume Knob Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Volume Knob Replacement: paso 3, imagen 1 de 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Volume Knob Replacement: paso 4, imagen 1 de 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Volume Knob Replacement: paso 5, imagen 1 de 3 Sony XAV-AX100 Volume Knob Replacement: paso 5, imagen 2 de 3 Sony XAV-AX100 Volume Knob Replacement: paso 5, imagen 3 de 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Volume Knob Replacement, Motherboard: paso 6, imagen 1 de 2 Sony XAV-AX100 Volume Knob Replacement, Motherboard: paso 6, imagen 2 de 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Volume Knob Replacement: paso 7, imagen 1 de 3 Sony XAV-AX100 Volume Knob Replacement: paso 7, imagen 2 de 3 Sony XAV-AX100 Volume Knob Replacement: paso 7, imagen 3 de 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Volume Knob Replacement, Display: paso 8, imagen 1 de 1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Volume Knob Replacement: paso 9, imagen 1 de 2 Sony XAV-AX100 Volume Knob Replacement: paso 9, imagen 2 de 2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Volume Knob Replacement, Display Board: paso 10, imagen 1 de 3 Sony XAV-AX100 Volume Knob Replacement, Display Board: paso 10, imagen 2 de 3 Sony XAV-AX100 Volume Knob Replacement, Display Board: paso 10, imagen 3 de 3
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Volume Knob Replacement: paso 11, imagen 1 de 1
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Volume Knob Replacement: paso 12, imagen 1 de 1
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Volume Knob Replacement: paso 13, imagen 1 de 1
    • Use a plastic opening tool to remove the display board from the radio.
  14. Sony XAV-AX100 Volume Knob Replacement, Volume Knob: paso 14, imagen 1 de 3 Sony XAV-AX100 Volume Knob Replacement, Volume Knob: paso 14, imagen 2 de 3 Sony XAV-AX100 Volume Knob Replacement, Volume Knob: paso 14, imagen 3 de 3
    • Remove the silver knob cover by pulling upwards on it.
    • Remove the plastic face plate.
    • Pull off the black knob.
Conclusión
Una persona más ha completado esta guía.
Abdulaziz Redha
Miembro Desde 02/22/18
741 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 2,712
