Saltar al contenido principal
Sony XAV-AX100 Motherboard Replacement
Qué necesitas
  1. Sony XAV-AX100 Motherboard Replacement, USB Cable: paso 1, imagen 1 de 3 Sony XAV-AX100 Motherboard Replacement, USB Cable: paso 1, imagen 2 de 3 Sony XAV-AX100 Motherboard Replacement, USB Cable: paso 1, imagen 3 de 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Motherboard Replacement: paso 2, imagen 1 de 2 Sony XAV-AX100 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Motherboard Replacement: paso 3, imagen 1 de 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Motherboard Replacement: paso 4, imagen 1 de 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Motherboard Replacement: paso 5, imagen 1 de 3 Sony XAV-AX100 Motherboard Replacement: paso 5, imagen 2 de 3 Sony XAV-AX100 Motherboard Replacement: paso 5, imagen 3 de 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 Sony XAV-AX100 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Motherboard Replacement: paso 7, imagen 1 de 3 Sony XAV-AX100 Motherboard Replacement: paso 7, imagen 2 de 3 Sony XAV-AX100 Motherboard Replacement: paso 7, imagen 3 de 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
Conclusión
Abdulaziz Redha
Miembro Desde 02/22/18
741 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Cagle Spring 2018 Miembro de USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Miembros
5 Guías creadas
Un comentario
Where to buy the motherboard ?
B.Keat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 25
Todo El Tiempo: 1,567
