Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Sony Walkman WM-4, utiliza nuestros manuales de servicio .
  1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: paso 1, imagen 1 de 2 Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: paso 1, imagen 2 de 2
    • Flip the Sony Walkman so that its rear side faces you.
    • Use a screwdriver to remove the two screws from the surface of the Walkman.
    • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
    • Remove the batteries from the Walkman.
  2. Sony Walkman WM-4 Teardown: paso 2, imagen 1 de 2 Sony Walkman WM-4 Teardown: paso 2, imagen 2 de 2
    • Turn over your Walkman and gently press the cover to open the cassette holder.
    • When the cassette holder is opened, you can see two more screws.
    • Using a screwdriver, remove the two screws.
  3. Sony Walkman WM-4 Teardown: paso 3, imagen 1 de 2 Sony Walkman WM-4 Teardown: paso 3, imagen 2 de 2
    • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
    • Be careful so you dont break the tabs!
    • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
lenzo
Miembro Desde 07/14/11
125 Reputación
1 Guía escrita
Un comentario
Drive belt trashed any ideas where to get one?
nz-tiger - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 38
Todo El Tiempo: 15,910
