Saltar al contenido principal
Sony Walkman NWZ-S764 Motherboard Replacement
Qué necesitas
  1. Sony Walkman NWZ-S764 Motherboard Replacement, Removing the back cover: paso 1, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement, Removing the back cover: paso 1, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement, Removing the back cover: paso 1, imagen 3 de 3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Motherboard Replacement: paso 2, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 2, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Motherboard Replacement: paso 3, imagen 1 de 2 Sony Walkman NWZ-S764 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Motherboard Replacement: paso 4, imagen 1 de 2 Sony Walkman NWZ-S764 Motherboard Replacement: paso 4, imagen 2 de 2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Motherboard Replacement, Removing the Bluetooth module: paso 5, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement, Removing the Bluetooth module: paso 5, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement, Removing the Bluetooth module: paso 5, imagen 3 de 3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Motherboard Replacement: paso 6, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 6, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
  7. Sony Walkman NWZ-S764 Motherboard Replacement, Audio Port: paso 7, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement, Audio Port: paso 7, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement, Audio Port: paso 7, imagen 3 de 3
    • Remove the two 2.8mm silver Phillips screws on the sides of the frame.
    • The two 2.8mm screws are on each side of the device.
    • Insert a plastic prying tool between the bottom of the case and the motherboard.
    • Pry up the assembly and lift it away from the case.
  8. Sony Walkman NWZ-S764 Motherboard Replacement: paso 8, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 8, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 8, imagen 3 de 3
    • Remove the yellow tape from the battery and volume control module.
    • Save tape for reassembly.
  9. Sony Walkman NWZ-S764 Motherboard Replacement: paso 9, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 9, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 9, imagen 3 de 3
    • Use a prying tool to pry under the volume control module.
    • This module is glued on, using too much force may damage or warp the module.
  10. Sony Walkman NWZ-S764 Motherboard Replacement: paso 10, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 10, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 10, imagen 3 de 3
    • Remove the tape from EMF shield and the LCD housing.
    • Lift up on the volume control ribbon.
  11. Sony Walkman NWZ-S764 Motherboard Replacement: paso 11, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 11, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 11, imagen 3 de 3
    • Insert a plastic opening tool under the battery and lift up to remove it.
    • The battery is glued on, too much force may damage the battery casing.
    • The battery is soldered to the motherboard, care should be taken to not place too much stress on the wires.
  12. Sony Walkman NWZ-S764 Motherboard Replacement: paso 12, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 12, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the black shielding tape from above the Hard Drive.
    • Peel the foam cover away from the hard drive.
    • Use a plastic opening tool to remove the EMF chip from the motherboard.
    • The hard drive is soldered onto the device. Be careful not to pull too hard on the hard drive.
  13. Sony Walkman NWZ-S764 Motherboard Replacement: paso 13, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 13, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 13, imagen 3 de 3
    • Remove the plastic bracket by pushing up with your thumb to expose the display connection.
  14. Sony Walkman NWZ-S764 Motherboard Replacement: paso 14, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 14, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 14, imagen 3 de 3
    • Use the flat end of a spudger to flip up the retaining flap on the audio jack module.
  15. Sony Walkman NWZ-S764 Motherboard Replacement: paso 15, imagen 1 de 2 Sony Walkman NWZ-S764 Motherboard Replacement: paso 15, imagen 2 de 2
    • Peel back the ribbon for the audio jack and remove the 1.8mm silver Phillips screw.
  16. Sony Walkman NWZ-S764 Motherboard Replacement: paso 16, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 16, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 16, imagen 3 de 3
    • Remove the mic casing by pushing up and in.
    • Remove the headphone jack and the bottom casing.
  17. Sony Walkman NWZ-S764 Motherboard Replacement, Motherboard: paso 17, imagen 1 de 2 Sony Walkman NWZ-S764 Motherboard Replacement, Motherboard: paso 17, imagen 2 de 2
    • Use the prying tool to remove the LCD ribbon wire.
  18. Sony Walkman NWZ-S764 Motherboard Replacement: paso 18, imagen 1 de 1
    • Lift up on the LCD ribbon and remove the two 1.8mm silver Phillips screws.
  19. Sony Walkman NWZ-S764 Motherboard Replacement: paso 19, imagen 1 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 19, imagen 2 de 3 Sony Walkman NWZ-S764 Motherboard Replacement: paso 19, imagen 3 de 3
    • Lift the motherboard away from the frame with your thumb to remove it from the device.
    • Pull the volume control module through the space in the frame.
    • If you are using the magnetic project pad or other magnetic surface to keep your screws, do not place the hard drive on or near the magnet.
Conclusión
John Ferguson
Miembro Desde 01/21/15
657 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-2, Brown Winter 2015 Miembro de USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,078
