Saltar al contenido principal
Sony Walkman NWZ-S764 Bluetooth module Replacement
Qué necesitas
  1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: paso 1, imagen 1 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: paso 1, imagen 2 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: paso 1, imagen 3 de 3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 2, imagen 1 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 2, imagen 2 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 3, imagen 1 de 2 Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 3, imagen 2 de 2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 4, imagen 1 de 2 Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 4, imagen 2 de 2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: paso 5, imagen 1 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: paso 5, imagen 2 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: paso 5, imagen 3 de 3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 6, imagen 1 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 6, imagen 2 de 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: paso 6, imagen 3 de 3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
Conclusión
John Ferguson
Miembro Desde 01/21/15
657 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-2, Brown Winter 2015 Miembro de USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 658
