Saltar al contenido principal
Sony Walkman NWZ-E438 Headphone Jack Replacement
Qué necesitas
  1. Sony Walkman NWZ-E438 Headphone Jack Replacement, Disassembling Sony Walkman NWZ-E438: paso 1, imagen 1 de 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Headphone Jack Replacement, Headphone Jack: paso 3, imagen 1 de 1
    • Unscrew the 1 screws around the headphone jack using Phillips PH000 screwdriver.
  4. Sony Walkman NWZ-E438 Headphone Jack Replacement: paso 4, imagen 1 de 2 Sony Walkman NWZ-E438 Headphone Jack Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using the fine pointed tweezers, unplug the cords connecting the headphone jack to the chip.
  5. Sony Walkman NWZ-E438 Headphone Jack Replacement: paso 5, imagen 1 de 3 Sony Walkman NWZ-E438 Headphone Jack Replacement: paso 5, imagen 2 de 3 Sony Walkman NWZ-E438 Headphone Jack Replacement: paso 5, imagen 3 de 3
    • Remove the headphone jack.
Conclusión
2 comentarios
hi there, i have mine apart but where do i get a spare one to refit, please help
lee manock - Contestar
Can you make a tutorial on how to replace the headphone jack on the sony nwz-s774?
petermedz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 823
