Saltar al contenido principal
Sony Walkman NWZ-E438 Battery Replacement
Qué necesitas
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: paso 1, imagen 1 de 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: paso 2, imagen 1 de 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: paso 4, imagen 1 de 1
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: paso 6, imagen 1 de 2 Sony Walkman NWZ-E438 Battery Replacement: paso 6, imagen 2 de 2
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: paso 7, imagen 1 de 2 Sony Walkman NWZ-E438 Battery Replacement: paso 7, imagen 2 de 2
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: paso 8, imagen 1 de 1
    • Remove battery.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 42
Todo El Tiempo: 6,483
