Saltar al contenido principal
Sony WH-H900n Earpad Cushion Replacement
Qué necesitas
  1. Sony WH-H900n Earpad Cushion Replacement, Earpad Cushion: paso 1, imagen 1 de 3 Sony WH-H900n Earpad Cushion Replacement, Earpad Cushion: paso 1, imagen 2 de 3 Sony WH-H900n Earpad Cushion Replacement, Earpad Cushion: paso 1, imagen 3 de 3
    • Place the edge opening tool between the headphones and earpad cushion, gently pry upward to release the clips securing the earpads.
    • Use the prying tool at different angles around the earpad.
    • Avoid using too much force when prying.
  2. Sony WH-H900n Earpad Cushion Replacement: paso 2, imagen 1 de 2 Sony WH-H900n Earpad Cushion Replacement: paso 2, imagen 2 de 2
    • Remove the earpad.
  3. Sony WH-H900n Earpad Cushion Replacement: paso 3, imagen 1 de 2 Sony WH-H900n Earpad Cushion Replacement: paso 3, imagen 2 de 2
    • Line up the back of the new earpad cushion with the six hooks on the inside of the headphone cup.
  4. Sony WH-H900n Earpad Cushion Replacement: paso 4, imagen 1 de 3 Sony WH-H900n Earpad Cushion Replacement: paso 4, imagen 2 de 3 Sony WH-H900n Earpad Cushion Replacement: paso 4, imagen 3 de 3
    • Make sure the seam of the earpad is facing the bottom.
  5. Sony WH-H900n Earpad Cushion Replacement: paso 5, imagen 1 de 3 Sony WH-H900n Earpad Cushion Replacement: paso 5, imagen 2 de 3 Sony WH-H900n Earpad Cushion Replacement: paso 5, imagen 3 de 3
    • Align the back of the earpad with the inside of the headphone cup.
    • Slide the earpad cushion onto the hooks in the ear cup.
  6. Sony WH-H900n Earpad Cushion Replacement: paso 6, imagen 1 de 2 Sony WH-H900n Earpad Cushion Replacement: paso 6, imagen 2 de 2
    • Hold the earpad cushion securely and press down until you hear a "click".
  7. Sony WH-H900n Earpad Cushion Replacement: paso 7, imagen 1 de 1
    • Repeat the steps for the other side.
Conclusión
Once you have completed the steps for both sides you are now able to enjoy your headphone just like when it was new.
idevn
Miembro Desde 01/11/24
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 69
Todo El Tiempo: 152
