Saltar al contenido principal
Sony WH-CH720N Speaker Replacement
Qué necesitas
  1. Sony WH-CH720N Speaker Replacement, Earmuff: paso 1, imagen 1 de 1
    • Place the headphones down on a table, and orient them in this way.
  2. Sony WH-CH720N Speaker Replacement: paso 2, imagen 1 de 3 Sony WH-CH720N Speaker Replacement: paso 2, imagen 2 de 3 Sony WH-CH720N Speaker Replacement: paso 2, imagen 3 de 3
    • Remove the earmuff.
    • Check introductions to ensure you remove the correct side earmuff for each repair guide!
  3. Sony WH-CH720N Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Sony WH-CH720N Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    • Remove the four 5 mm screws holding the speaker housing onto the headphones.
    • Move the now detached speaker housing to the side, being careful of the wires.
  4. Sony WH-CH720N Speaker Replacement: paso 4, imagen 1 de 2 Sony WH-CH720N Speaker Replacement: paso 4, imagen 2 de 2
    • On the backside of the speaker housing, remove the four 3 mm screws to detach the panel.
  5. Sony WH-CH720N Speaker Replacement: paso 5, imagen 1 de 3 Sony WH-CH720N Speaker Replacement: paso 5, imagen 2 de 3 Sony WH-CH720N Speaker Replacement: paso 5, imagen 3 de 3
    • With the speaker panel removed, desolder the wires connecting the speaker.
    • Use a heat gun to loosen the glue around the speaker inside the housing.
    • Finally, take the metal prying tool, and carefully remove the speaker.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 38
Todo El Tiempo: 105
