Saltar al contenido principal
Sony WH-1000XM4 Motherboard Replacement
Qué necesitas
  1. Sony WH-1000XM4 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Motherboard Replacement: paso 2, imagen 1 de 1
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • Repeat around the perimeter of the ear pad until it is loose.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the left ear pad.
  4. Sony WH-1000XM4 Motherboard Replacement: paso 4, imagen 1 de 1
    • Remove the foam liner from the left ear cup's speaker.
  5. Sony WH-1000XM4 Motherboard Replacement: paso 5, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover.
  6. Sony WH-1000XM4 Motherboard Replacement: paso 6, imagen 1 de 1
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the left ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with many cables.
  7. Sony WH-1000XM4 Motherboard Replacement: paso 7, imagen 1 de 1
    • Unscrew the 4 screws in the corners of the motherboard to loosen it from the left ear cup assembly.
  8. Sony WH-1000XM4 Motherboard Replacement: paso 8, imagen 1 de 1
    • Carefully remove the cable ribbon from the bottom of the motherboard.
  9. Sony WH-1000XM4 Motherboard Replacement: paso 9, imagen 1 de 1
    • Carefully remove the multipin connector (multiple colorful wires) from the side of the motherboard.
  10. Sony WH-1000XM4 Motherboard Replacement: paso 10, imagen 1 de 1
    • Carefully lift the motherboard out from the ear cup to access the other cable ribbons and connectors.
  11. Sony WH-1000XM4 Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove wires from the side or bottom of the motherboard that are attached by pin connectors.
  12. Sony WH-1000XM4 Motherboard Replacement: paso 12, imagen 1 de 1
    • Desolder the remaining wires that are attached to the motherboard.
    • Repeat steps in reverse order to reassemble the headphones after seating the new motherboard.
    • Reference the Service Manual on the Sony WH-1000XM4 main page on the IFixIt website to verify correct wire connections.
Conclusión
Spencer Decker
Miembro Desde 11/09/23
499 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-1, Harley Fall 2023 Miembro de IUPUI, Team 2-1, Harley Fall 2023
IUPUI-HARLEY-F23S2G1
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 13
Ultimos 7 días: 68
Ultimos 30 días: 277
Todo El Tiempo: 1,959
