Saltar al contenido principal
Sony Vaio VPCW21FX RAM Replacement
Qué necesitas
  1. Sony Vaio VPCW21FX RAM Replacement, Battery: paso 1, imagen 1 de 3 Sony Vaio VPCW21FX RAM Replacement, Battery: paso 1, imagen 2 de 3 Sony Vaio VPCW21FX RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX RAM Replacement: paso 2, imagen 1 de 3 Sony Vaio VPCW21FX RAM Replacement: paso 2, imagen 2 de 3 Sony Vaio VPCW21FX RAM Replacement: paso 2, imagen 3 de 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX RAM Replacement, RAM: paso 3, imagen 1 de 3 Sony Vaio VPCW21FX RAM Replacement, RAM: paso 3, imagen 2 de 3 Sony Vaio VPCW21FX RAM Replacement, RAM: paso 3, imagen 3 de 3
    • Loosen but do not remove the screw over RAM cover panel.
    • With the screw loosened but not removed, lift up and remove the panel.
  4. Sony Vaio VPCW21FX RAM Replacement: paso 4, imagen 1 de 3 Sony Vaio VPCW21FX RAM Replacement: paso 4, imagen 2 de 3 Sony Vaio VPCW21FX RAM Replacement: paso 4, imagen 3 de 3
    • Locate the mounting bracket holding the RAM Chips in the computer.
    • Pull silver tabs away from the chip.
    • The chip will pop up, this is normal.
    • Don't touch gold pins on RAM chip.
  5. Sony Vaio VPCW21FX RAM Replacement: paso 5, imagen 1 de 2 Sony Vaio VPCW21FX RAM Replacement: paso 5, imagen 2 de 2
    • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
    • Repeat previous steps for second RAM chip.
Conclusión
Nicholas Corcoran
Miembro Desde 03/08/17
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 3,333
