Saltar al contenido principal
Sony Vaio VPCW21FX Keyboard Replacement
Qué necesitas
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: paso 2, imagen 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement: paso 2, imagen 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement: paso 2, imagen 3 de 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: paso 4, imagen 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement: paso 4, imagen 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement: paso 4, imagen 3 de 3
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: paso 5, imagen 1 de 2 Sony Vaio VPCW21FX Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: paso 6, imagen 1 de 3 Sony Vaio VPCW21FX Keyboard Replacement: paso 6, imagen 2 de 3 Sony Vaio VPCW21FX Keyboard Replacement: paso 6, imagen 3 de 3
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
Conclusión
Nicholas Corcoran
Miembro Desde 03/08/17
401 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 23
Todo El Tiempo: 2,255
