Saltar al contenido principal
Sony Vaio VPCW211AX Keyboard Replacement
Qué necesitas
  1. Sony Vaio VPCW211AX Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Start with the laptop face up on a flat surface.
  2. Sony Vaio VPCW211AX Keyboard Replacement: paso 2, imagen 1 de 1
    • Open the laptop with the keyboard facing you.
  3. Sony Vaio VPCW211AX Keyboard Replacement: paso 3, imagen 1 de 2 Sony Vaio VPCW211AX Keyboard Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Sony Vaio VPCW211AX Keyboard Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCW211AX Keyboard Replacement: paso 4, imagen 2 de 2
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
Giselle Dougan
Miembro Desde 01/31/18
760 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 534
