Saltar al contenido principal
Sony Vaio VPCEL17FX Hard Drive Replacement
Qué necesitas
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: paso 2, imagen 1 de 2 Sony Vaio VPCEL17FX Hard Drive Replacement: paso 2, imagen 2 de 2
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
Conclusión
The installation/replacement is a very easy task that can be done by anyone.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 615
