Saltar al contenido principal
Sony Vaio VPCEG37FM Optical Drive Replacement
Qué necesitas
  1. Sony Vaio VPCEG37FM Optical Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Unlock the battery by sliding the lock upwards.
  2. Sony Vaio VPCEG37FM Optical Drive Replacement: paso 2, imagen 1 de 2 Sony Vaio VPCEG37FM Optical Drive Replacement: paso 2, imagen 2 de 2
    • Slide the release upwards and lift out the battery to remove.
    • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
  3. Sony Vaio VPCEG37FM Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 2 Sony Vaio VPCEG37FM Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, unscrew the 6.5 mm screw.
  4. Sony Vaio VPCEG37FM Optical Drive Replacement: paso 4, imagen 1 de 1
    • Grab and slide out the optical drive to remove.
Conclusión
Ramon Ogaz
Miembro Desde 09/25/17
104 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 18
Ultimos 30 días: 37
Todo El Tiempo: 1,753
