Saltar al contenido principal
Sony Vaio VPCEA3C5E RAM Replacement
Qué necesitas
  1. Sony Vaio VPCEA3C5E RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Remove the single Phillips #00 screw from the back cover of the laptop.
  2. Sony Vaio VPCEA3C5E RAM Replacement: paso 2, imagen 1 de 1
    • Lift the cover up and remove it from the computer.
  3. Sony Vaio VPCEA3C5E RAM Replacement: paso 3, imagen 1 de 1
    • Identify the two RAM pieces.
  4. Sony Vaio VPCEA3C5E RAM Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCEA3C5E RAM Replacement: paso 4, imagen 2 de 2
    • Push out the two outer white catch pieces holding the both sides of the RAM in position. Begin gently removing the RAM from its position.
  5. Sony Vaio VPCEA3C5E RAM Replacement: paso 5, imagen 1 de 1
    • Once you have the RAM out on its own, replace it or put it back into the correct position.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 22
Todo El Tiempo: 982
