Saltar al contenido principal
Sony Vaio VPCEA3C5E Key Replacement
Qué necesitas
  1. Sony Vaio VPCEA3C5E Key Replacement, Key: paso 1, imagen 1 de 1
    • Use a pair of tweezers like the one shown in the picture.
  2. Sony Vaio VPCEA3C5E Key Replacement: paso 2, imagen 1 de 1
    • Use the tweezers to get under the key piece on the keyboard as shown in the picture.
  3. Sony Vaio VPCEA3C5E Key Replacement: paso 3, imagen 1 de 1
    • Carefully lift the key piece upward to remove it completely.
  4. Sony Vaio VPCEA3C5E Key Replacement: paso 4, imagen 1 de 1
    • After the key is removed, you should be able to see the part underneath the key where it can be replaced.
Conclusión
To reassemble your device, follow these instructions carefully in reverse order.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 38
Todo El Tiempo: 933
