Saltar al contenido principal
Sony Vaio VPCCW17FX Webcam Replacement
Qué necesitas
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: paso 2, imagen 1 de 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: paso 3, imagen 1 de 2 Sony Vaio VPCCW17FX Webcam Replacement: paso 3, imagen 2 de 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCCW17FX Webcam Replacement: paso 4, imagen 2 de 2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: paso 5, imagen 1 de 2 Sony Vaio VPCCW17FX Webcam Replacement: paso 5, imagen 2 de 2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: paso 6, imagen 1 de 3 Sony Vaio VPCCW17FX Webcam Replacement: paso 6, imagen 2 de 3 Sony Vaio VPCCW17FX Webcam Replacement: paso 6, imagen 3 de 3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Conclusión
Tiffani Beck
Miembro Desde 03/20/17
219 Reputación
2 Guías creadas
Equipo
Texas Tech, Team S8-G5, Bennett Spring 2017 Miembro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,170
