Saltar al contenido principal
Sony Vaio VPCCW17FX Speakers Replacement
Qué necesitas
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: paso 2, imagen 1 de 1
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: paso 3, imagen 1 de 2 Sony Vaio VPCCW17FX Speakers Replacement: paso 3, imagen 2 de 2
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCCW17FX Speakers Replacement: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: paso 6, imagen 1 de 1
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: paso 7, imagen 1 de 2 Sony Vaio VPCCW17FX Speakers Replacement: paso 7, imagen 2 de 2
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: paso 8, imagen 1 de 2 Sony Vaio VPCCW17FX Speakers Replacement: paso 8, imagen 2 de 2
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: paso 9, imagen 1 de 3 Sony Vaio VPCCW17FX Speakers Replacement: paso 9, imagen 2 de 3 Sony Vaio VPCCW17FX Speakers Replacement: paso 9, imagen 3 de 3
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
Conclusión
Brianna Rukes
Miembro Desde 03/21/17
101 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S8-G5, Bennett Spring 2017 Miembro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 546
