Saltar al contenido principal
Sony Vaio VPCCW17FX LCD Screen Replacement
Qué necesitas
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 2, imagen 1 de 1
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 3, imagen 1 de 2 Sony Vaio VPCCW17FX LCD Screen Replacement: paso 3, imagen 2 de 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCCW17FX LCD Screen Replacement: paso 4, imagen 2 de 2
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 5, imagen 1 de 1
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 6, imagen 1 de 2 Sony Vaio VPCCW17FX LCD Screen Replacement: paso 6, imagen 2 de 2
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 7, imagen 1 de 2 Sony Vaio VPCCW17FX LCD Screen Replacement: paso 7, imagen 2 de 2
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: paso 8, imagen 1 de 1
    • The screen can now be removed.
Conclusión
Una persona más ha completado esta guía.
Seowon Song
Miembro Desde 03/20/17
113 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S8-G5, Bennett Spring 2017 Miembro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,177
