Saltar al contenido principal
Sony Vaio VPCCW17FX Hard Drive Replacement
Qué necesitas
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: paso 3, imagen 1 de 2 Sony Vaio VPCCW17FX Hard Drive Replacement: paso 3, imagen 2 de 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: paso 4, imagen 1 de 2 Sony Vaio VPCCW17FX Hard Drive Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: paso 5, imagen 1 de 3 Sony Vaio VPCCW17FX Hard Drive Replacement: paso 5, imagen 2 de 3 Sony Vaio VPCCW17FX Hard Drive Replacement: paso 5, imagen 3 de 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: paso 6, imagen 1 de 3 Sony Vaio VPCCW17FX Hard Drive Replacement: paso 6, imagen 2 de 3 Sony Vaio VPCCW17FX Hard Drive Replacement: paso 6, imagen 3 de 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Conclusión
Tiffani Beck
Miembro Desde 03/20/17
219 Reputación
2 Guías creadas
Equipo
Texas Tech, Team S8-G5, Bennett Spring 2017 Miembro de Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 1,753
