Saltar al contenido principal
Sony Vaio VPCCW17FX Fan Replacement
Qué necesitas
  1. Sony Vaio VPCCW17FX Fan Replacement, Back case: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Fan Replacement: paso 2, imagen 1 de 3 Sony Vaio VPCCW17FX Fan Replacement: paso 2, imagen 2 de 3 Sony Vaio VPCCW17FX Fan Replacement: paso 2, imagen 3 de 3
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Fan Replacement: paso 3, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Fan Replacement: paso 4, imagen 1 de 3 Sony Vaio VPCCW17FX Fan Replacement: paso 4, imagen 2 de 3 Sony Vaio VPCCW17FX Fan Replacement: paso 4, imagen 3 de 3
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Fan Replacement: paso 5, imagen 1 de 3 Sony Vaio VPCCW17FX Fan Replacement: paso 5, imagen 2 de 3 Sony Vaio VPCCW17FX Fan Replacement: paso 5, imagen 3 de 3
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Fan Replacement: paso 6, imagen 1 de 1
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Fan Replacement: paso 7, imagen 1 de 1
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
  8. Sony Vaio VPCCW17FX Fan Replacement, Fan: paso 8, imagen 1 de 3 Sony Vaio VPCCW17FX Fan Replacement, Fan: paso 8, imagen 2 de 3 Sony Vaio VPCCW17FX Fan Replacement, Fan: paso 8, imagen 3 de 3
    • Locate the fan (top-right corner of the computer).
    • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
  9. Sony Vaio VPCCW17FX Fan Replacement: paso 9, imagen 1 de 2 Sony Vaio VPCCW17FX Fan Replacement: paso 9, imagen 2 de 2
    • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
    • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
  10. Sony Vaio VPCCW17FX Fan Replacement: paso 10, imagen 1 de 2 Sony Vaio VPCCW17FX Fan Replacement: paso 10, imagen 2 de 2
    • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,093
