Saltar al contenido principal
Sony Vaio VGN-TXN25N Battery Replacement
  1. Sony Vaio VGN-TXN25N Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the computer so that the bottom is facing up.
    • Look to the long edge where the computer screen is hinged and find the "release slide". It is located at the top left corner of the square indent.
  2. Sony Vaio VGN-TXN25N Battery Replacement: paso 2, imagen 1 de 1
    • Use your finger to slide the release to the left.
  3. Sony Vaio VGN-TXN25N Battery Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-TXN25N Battery Replacement: paso 3, imagen 2 de 2
    • While holding the release slide with one hand, use your opposite hand to pull the battery from its slot by gently shaking the battery left and right to help slide it out.
Conclusión
Una persona más ha completado esta guía.
Austen
Miembro Desde 04/03/12
32 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-3, Forte Spring 2012 Miembro de Cal Poly, Team 5-3, Forte Spring 2012
CPSU-FORTE-S12S5G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 18
Todo El Tiempo: 1,859
