Saltar al contenido principal
Sony Vaio VGN-SZ120P Speaker Assembly Replacement
Qué necesitas
  1. Sony Vaio VGN-SZ120P Speaker Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 2, imagen 1 de 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Speaker Assembly Replacement, Keyboard: paso 3, imagen 1 de 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 4, imagen 1 de 2 Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 4, imagen 2 de 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 5, imagen 1 de 2 Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 5, imagen 2 de 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Speaker Assembly Replacement, Mouse Assembly: paso 6, imagen 1 de 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 7, imagen 1 de 2 Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 7, imagen 2 de 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio VGN-SZ120P Speaker Assembly Replacement, Speaker Assembly: paso 8, imagen 1 de 3 Sony Vaio VGN-SZ120P Speaker Assembly Replacement, Speaker Assembly: paso 8, imagen 2 de 3 Sony Vaio VGN-SZ120P Speaker Assembly Replacement, Speaker Assembly: paso 8, imagen 3 de 3
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  9. Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Pop off the antenna using a pair of tweezers.
  10. Sony Vaio VGN-SZ120P Speaker Assembly Replacement: paso 10, imagen 1 de 1
    • Remove the seven philips screws holding the speaker assembly in place.
    • Before removing the assembly, disconnect the ribbon cable located at the top left corner of the assembly.
    • The speaker assembly will come off with the display assembly.
Conclusión
Una persona más ha completado esta guía.
Ryan
Miembro Desde 04/11/10
154 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 25-89, Amido Spring 2010 Miembro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Miembros
63 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 4,402
