Saltar al contenido principal
Sony Vaio VGN-SR140E Screen Replacement
Qué necesitas
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: paso 2, imagen 1 de 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-SR140E Screen Replacement: paso 3, imagen 2 de 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: paso 4, imagen 1 de 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: paso 4, imagen 2 de 3 Sony Vaio VGN-SR140E Screen Replacement, Screen: paso 4, imagen 3 de 3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: paso 5, imagen 1 de 1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: paso 6, imagen 1 de 2 Sony Vaio VGN-SR140E Screen Replacement: paso 6, imagen 2 de 2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: paso 7, imagen 1 de 3 Sony Vaio VGN-SR140E Screen Replacement: paso 7, imagen 2 de 3 Sony Vaio VGN-SR140E Screen Replacement: paso 7, imagen 3 de 3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: paso 8, imagen 1 de 3 Sony Vaio VGN-SR140E Screen Replacement: paso 8, imagen 2 de 3 Sony Vaio VGN-SR140E Screen Replacement: paso 8, imagen 3 de 3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: paso 9, imagen 1 de 1
    • The screen can now be removed.
Conclusión
Jeremy
Miembro Desde 03/18/15
722 Reputación
4 Guías creadas
Equipo
Michigan Tech, Team 1-6, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,128
