Saltar al contenido principal
Sony Vaio VGN-SR140E RAM Replacement
Qué necesitas
  1. Sony Vaio VGN-SR140E RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E RAM Replacement: paso 2, imagen 1 de 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E RAM Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-SR140E RAM Replacement: paso 3, imagen 2 de 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E RAM Replacement: paso 5, imagen 1 de 2 Sony Vaio VGN-SR140E RAM Replacement: paso 5, imagen 2 de 2
    • Lift the thin black plastic cover to access the RAM.
  6. Sony Vaio VGN-SR140E RAM Replacement: paso 6, imagen 1 de 2 Sony Vaio VGN-SR140E RAM Replacement: paso 6, imagen 2 de 2
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Sony Vaio VGN-SR140E RAM Replacement: paso 7, imagen 1 de 3 Sony Vaio VGN-SR140E RAM Replacement: paso 7, imagen 2 de 3 Sony Vaio VGN-SR140E RAM Replacement: paso 7, imagen 3 de 3
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
Conclusión
Jeremy
Miembro Desde 03/18/15
722 Reputación
4 Guías creadas
Equipo
Michigan Tech, Team 1-6, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 480
