Saltar al contenido principal
Sony Vaio VGN-SR140E Hard Drive Replacement
Qué necesitas
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-SR140E Hard Drive Replacement: paso 3, imagen 2 de 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: paso 5, imagen 1 de 1
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: paso 6, imagen 1 de 1
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: paso 7, imagen 1 de 2 Sony Vaio VGN-SR140E Hard Drive Replacement: paso 7, imagen 2 de 2
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: paso 8, imagen 1 de 2 Sony Vaio VGN-SR140E Hard Drive Replacement: paso 8, imagen 2 de 2
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
Conclusión
Una persona más ha completado esta guía.
Jeremy
Miembro Desde 03/18/15
722 Reputación
4 Guías creadas
Equipo
Michigan Tech, Team 1-6, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 19
Todo El Tiempo: 942
