Saltar al contenido principal
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
Qué necesitas
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: paso 2, imagen 1 de 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-SR140E CD/DVD Drive Replacement: paso 3, imagen 2 de 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: paso 4, imagen 1 de 1
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: paso 5, imagen 1 de 1
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: paso 6, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: paso 7, imagen 1 de 1
    • Gently slide the CD/DVD drive out of the laptop.
Conclusión
Jeremy
Miembro Desde 03/18/15
722 Reputación
4 Guías creadas
Equipo
Michigan Tech, Team 1-6, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 978
