Saltar al contenido principal
Sony Vaio VGN-SR140E Battery Replacement
Qué necesitas
  1. Sony Vaio VGN-SR140E Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Battery Replacement: paso 2, imagen 1 de 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Battery Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-SR140E Battery Replacement: paso 3, imagen 2 de 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
Conclusión
To reinstall the battery, follow these steps in reverse order
William Thomas
Miembro Desde 03/18/15
125 Reputación
1 Guía escrita
Equipo
Michigan Tech, Team 1-6, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-6, Lauer Spring 2015
MTU-LAUER-S15S1G6
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 16
Todo El Tiempo: 1,100
