Saltar al contenido principal
Sony Vaio VGN-S260 Fan Replacement
Qué necesitas
  1. Sony Vaio VGN-S260 Fan Replacement, Battery: paso 1, imagen 1 de 3 Sony Vaio VGN-S260 Fan Replacement, Battery: paso 1, imagen 2 de 3 Sony Vaio VGN-S260 Fan Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Fan Replacement: paso 2, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 2, imagen 2 de 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Fan Replacement, Keyboard: paso 3, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement, Keyboard: paso 3, imagen 2 de 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Fan Replacement: paso 4, imagen 1 de 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Fan Replacement: paso 5, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 5, imagen 2 de 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Fan Replacement: paso 6, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 6, imagen 2 de 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Fan Replacement, Upper Casing: paso 7, imagen 1 de 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Fan Replacement: paso 8, imagen 1 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 8, imagen 2 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 8, imagen 3 de 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Fan Replacement: paso 9, imagen 1 de 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Fan Replacement: paso 10, imagen 1 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 10, imagen 2 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 10, imagen 3 de 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Fan Replacement: paso 11, imagen 1 de 1
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Fan Replacement, Optical Drive: paso 12, imagen 1 de 1
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Fan Replacement: paso 13, imagen 1 de 1
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Fan Replacement: paso 14, imagen 1 de 1
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Fan Replacement: paso 15, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 15, imagen 2 de 2
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  16. Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: paso 16, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: paso 16, imagen 2 de 2
    • Remove the blue ribbon from the Ethernet Circuit Board.
  17. Sony Vaio VGN-S260 Fan Replacement: paso 17, imagen 1 de 1
    • Remove the screws near the Ethernet Port circuit board.
  18. Sony Vaio VGN-S260 Fan Replacement: paso 18, imagen 1 de 1
    • Remove the screws for the second ethernet circuit board.
  19. Sony Vaio VGN-S260 Fan Replacement: paso 19, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 19, imagen 2 de 2
    • Remove the ethernet ports.
  20. Sony Vaio VGN-S260 Fan Replacement, Hard Drive: paso 20, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement, Hard Drive: paso 20, imagen 2 de 2
    • Remove the screws holding the hard drive casing in place.
  21. Sony Vaio VGN-S260 Fan Replacement: paso 21, imagen 1 de 1
    • Find orange ribbon that is connected to the hard drive.
    • Find the holder of the ribbon and pop the ribbon off from it.
  22. Sony Vaio VGN-S260 Fan Replacement: paso 22, imagen 1 de 1
    • Remove the casing and the orange ribbon.
  23. Sony Vaio VGN-S260 Fan Replacement, Power Adapter: paso 23, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement, Power Adapter: paso 23, imagen 2 de 2
    • Locate the yellow power adapter.
    • Follow its wire to white logic board connector.
    • Pull out the wire from white logic board connector.
  24. Sony Vaio VGN-S260 Fan Replacement: paso 24, imagen 1 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 24, imagen 2 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 24, imagen 3 de 3
    • Locate the screws on the fan filter casing.
    • Remove these screws.
  25. Sony Vaio VGN-S260 Fan Replacement: paso 25, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 25, imagen 2 de 2
    • Remove the screw next to the yellow power adapter.
    • Lift out power adapter and fan filter.
  26. Sony Vaio VGN-S260 Fan Replacement, Motherboard: paso 26, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement, Motherboard: paso 26, imagen 2 de 2
    • Remove screws on the motherboard.
  27. Sony Vaio VGN-S260 Fan Replacement: paso 27, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 27, imagen 2 de 2
    • Remove the nut using a 5mm nut driver.
    • Using a magnetic screwdriver handle will also work as well.
  28. Sony Vaio VGN-S260 Fan Replacement: paso 28, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 28, imagen 2 de 2
    • Remove the LCD display ribbon with a nylon spudger.
    • This is difficult to remove.
  29. Sony Vaio VGN-S260 Fan Replacement: paso 29, imagen 1 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 29, imagen 2 de 3 Sony Vaio VGN-S260 Fan Replacement: paso 29, imagen 3 de 3
    • Gently lift the motherboard from the laptop.
    • The motherboard will be attached to the network wireless chip, which is also attached to the base of the laptop.
    • Remove the chip by popping the tabs on the side.
    • Slide out the network card.
    • You are now free to take the motherboard away from the base.
  30. Sony Vaio VGN-S260 Fan Replacement, Fan: paso 30, imagen 1 de 1
    • Disconnect the fan wire from the logic board
  31. Sony Vaio VGN-S260 Fan Replacement: paso 31, imagen 1 de 2 Sony Vaio VGN-S260 Fan Replacement: paso 31, imagen 2 de 2
    • Turn the logic board over and Locate the screws connecting the fan to the logic board
    • Gently remove the fan from the logic board
Conclusión
2 personas más completaron esta guía.
Jeffrey Bryan
Miembro Desde 04/20/10
570 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 16-4, Maness Spring 2010 Miembro de Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Miembros
30 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 8,341
