Saltar al contenido principal
Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement
Qué necesitas
  1. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement, Optical Drive: paso 1, imagen 1 de 1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement: paso 2, imagen 1 de 1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Conclusión
Una persona más ha completado esta guía.
Kevin McGowan
Miembro Desde 04/22/14
619 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-17, Regan Spring 2014 Miembro de Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Miembros
18 Guías creadas
Un comentario
Has anyone found a suitable optical enclosure that would accommodate the front edge of this drive? Every enclosure I've seen so far would have the door protruding past the enclosure's opening (as opposed to sitting flush with the enclosure's opening), leaving its top edge unprotected.
Lotus Flower - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 1,743
