Introducción
The battery of the Vaio VGN-NW240F is on the underside on the laptop. The removal of the battery is an important step that should be taken for any other repair, displacement, or dis-assembly.
Power off the laptop.
Unplug the charging cable and any other cables plugged into the laptop.
Turn the laptop over so that the back panel is facing upwards.
To reassemble your battery, line up the battery and slide it in until the second lock (left hand switch) clicks. Then lock the 1st switch.
4 personas más completaron esta guía.
