Saltar al contenido principal
Sony Vaio VGN-FW21Z Power Adapter Replacement
Qué necesitas
  1. Sony Vaio VGN-FW21Z Power Adapter Replacement, Battery: paso 1, imagen 1 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement, Battery: paso 1, imagen 2 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 2, imagen 1 de 2 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 2, imagen 2 de 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-FW21Z Power Adapter Replacement, Keyboard: paso 3, imagen 1 de 2 Sony Vaio VGN-FW21Z Power Adapter Replacement, Keyboard: paso 3, imagen 2 de 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 4, imagen 1 de 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 5, imagen 1 de 2 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 5, imagen 2 de 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 6, imagen 1 de 2 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 6, imagen 2 de 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-FW21Z Power Adapter Replacement, Upper Casing: paso 7, imagen 1 de 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 8, imagen 1 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 8, imagen 2 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 8, imagen 3 de 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 9, imagen 1 de 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 10, imagen 1 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 10, imagen 2 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 10, imagen 3 de 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 11, imagen 1 de 1
    • Remove the upper casing.
  12. Sony Vaio VGN-FW21Z Power Adapter Replacement, Power Adapter: paso 12, imagen 1 de 2 Sony Vaio VGN-FW21Z Power Adapter Replacement, Power Adapter: paso 12, imagen 2 de 2
    • Locate the yellow power adapter.
    • Follow its wire to white logic board connector.
    • Pull out the wire from white logic board connector.
  13. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 13, imagen 1 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 13, imagen 2 de 3 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 13, imagen 3 de 3
    • Locate the screws on the fan filter casing.
    • Remove these screws.
  14. Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 14, imagen 1 de 2 Sony Vaio VGN-FW21Z Power Adapter Replacement: paso 14, imagen 2 de 2
    • Remove the screw next to the yellow power adapter.
    • Lift out power adapter and fan filter.
Conclusión
2 personas más completaron esta guía.
Jeffrey Bryan
Miembro Desde 04/20/10
570 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 16-4, Maness Spring 2010 Miembro de Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Miembros
30 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 8,477
