Saltar al contenido principal
Sony Vaio VGN-FS640 Hard Drive Replacement
Qué necesitas
  1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 Hard Drive Replacement: paso 3, imagen 1 de 2 Sony Vaio VGN-FS640 Hard Drive Replacement: paso 3, imagen 2 de 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  5. Sony Vaio VGN-FS640 Hard Drive Replacement: paso 5, imagen 1 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement: paso 5, imagen 2 de 3 Sony Vaio VGN-FS640 Hard Drive Replacement: paso 5, imagen 3 de 3
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
Conclusión
2 personas más completaron esta guía.
Matt McCarty
Miembro Desde 04/15/10
220 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 24-32, Regan Spring 2010 Miembro de Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Miembros
16 Guías creadas
Un comentario
cant sign to recover my external hard drive
manivanan88 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 10,582
