Saltar al contenido principal
Sony Vaio VGN-FS640 Fan Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: paso 1, imagen 1 de 1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Fan Replacement: paso 2, imagen 1 de 1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Fan Replacement: paso 3, imagen 1 de 1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Fan Replacement: paso 4, imagen 1 de 1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Fan Replacement: paso 5, imagen 1 de 1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Fan Replacement: paso 6, imagen 1 de 1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Fan Replacement: paso 7, imagen 1 de 1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Fan Replacement: paso 8, imagen 1 de 1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Fan Replacement: paso 9, imagen 1 de 1
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Sony Vaio VGN-FS640 Fan Replacement, Fan: paso 10, imagen 1 de 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: paso 10, imagen 2 de 3 Sony Vaio VGN-FS640 Fan Replacement, Fan: paso 10, imagen 3 de 3
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Sony Vaio VGN-FS640 Fan Replacement: paso 11, imagen 1 de 2 Sony Vaio VGN-FS640 Fan Replacement: paso 11, imagen 2 de 2
    • Remove the four screws securing the fan.
  12. Sony Vaio VGN-FS640 Fan Replacement: paso 12, imagen 1 de 2 Sony Vaio VGN-FS640 Fan Replacement: paso 12, imagen 2 de 2
    • Gently lift out the fan.
    • Do not forcefully pull the fan away. This may damage the circuit board.
  13. Sony Vaio VGN-FS640 Fan Replacement: paso 13, imagen 1 de 2 Sony Vaio VGN-FS640 Fan Replacement: paso 13, imagen 2 de 2
    • Gently disconnect the remaining wire connecting the fan to the circuit board.
    • Remove the fan from the laptop.
Conclusión
Una persona más ha completado esta guía.
Geoffrey
Miembro Desde 03/28/14
252 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 16
Todo El Tiempo: 550
