Saltar al contenido principal
Sony Vaio VGN-FS640 Backplate Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Sony Vaio VGN-FS640 Backplate Replacement, Backplate: paso 1, imagen 1 de 1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Backplate Replacement: paso 2, imagen 1 de 1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Backplate Replacement: paso 3, imagen 1 de 1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Backplate Replacement: paso 4, imagen 1 de 1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Backplate Replacement: paso 5, imagen 1 de 1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Backplate Replacement: paso 6, imagen 1 de 1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Backplate Replacement: paso 7, imagen 1 de 1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Backplate Replacement: paso 8, imagen 1 de 1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Backplate Replacement: paso 9, imagen 1 de 1
    • Remove the backplate of the laptop by pulling it away from the laptop.
Conclusión
Una persona más ha completado esta guía.
shamaz
Miembro Desde 03/12/14
125 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 363
