Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Sony Vaio Tap 11 Power Jack Replacement
Qué necesitas
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: paso 1, imagen 1 de 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: paso 2, imagen 1 de 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: paso 3, imagen 1 de 2 Sony Vaio Tap 11 Power Jack Replacement: paso 3, imagen 2 de 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: paso 5, imagen 1 de 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: paso 6, imagen 1 de 1
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: paso 7, imagen 1 de 1
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: paso 8, imagen 1 de 1
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: paso 9, imagen 1 de 1
    • Pull out the cable and jack assembly.
Conclusión
3 personas más completaron esta guía.
Alexander Bridges
Miembro Desde 09/16/15
1,217 Reputación
7 Guías creadas
Equipo
IUPUI, Team 1-2, Harley Fall 2015 Miembro de IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
Miembros de 4
20 Guías creadas
2Guía Comentarios
I wonder if you have the part number or can supply this power jack?
James Toal - Contestar Compartir
Yes, Where can I find this replacement part?
mikebeard65 - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 2,130
